Brief Description: Rt Wing #18 - Riveted Top Outboard Skin
Furge came over after work today and helped me rivet on the top outboard skin. It went on perfect.
After that was done I had to remove the fuel tank in order to rivet the most forward holes on the main rib flanges to the spar (both top and bottom). Those rivets are installed flush with spar flange and sit under the tank skin. I failed to install those rivets prior to installing the tank, and didn't notice it until I had already started riveting on the inboard top skin. Oh well, easy fix. Just have to re-install the tank and get ready to remove the wing from the stands.
Nary a cleko holding anything on to this wing...
Black arrows show the holes that needed rivets after removing the tank.
