Riveted the last internal fuel tank rib. After covering the shop heads with sealant, and went ahead and cleaned the area around the inboard end ribs and started to lay a filet of sealant where the rib meets the skin. I couldn't do it all because I had not yet riveted in the rib tip re-inforcement plate, but it was a good use of the left over sealant.
