Located and drilled all the holes for the nav antenna coax. That wire will go in the forward tooling holes of the main ribs. I want to keep it out of the conduit with all the other wires. I had already drilled the conduit holes back when I was prepping the left wing ribs. Deburred all the holes and clecoed the right wing skeleton together. Next step is to drill the ribs to the front and rear spar. I'm trying to figure out if I have enough primer to paint the ribs...I probably don't...I should go ahead and order some more to prevent a work stoppage.
