Brief Description: Left Fuel Tank #19 - Access Plate and Sender
After reading through alot of archives and threads concerning the matter, I set aside the cork and rubber gaskets for the plate and sending unit, and just used pro-seal to install them. After cleaning all the parts, I smeared sealant around the access hole, put the plate in place, and then installed each screw after covering the threads in sealant. Then I did the same thing with the fuel level sender. LEFT TANK IS COMPLETE!!!
Now I just have to let it set up for awhile then do the leak check....keep your fingers crossed....!!
