Brief Description: Left Fuel Tank #7 - Access Plate Fabrication
Completed the work on the inboard tank end-rib for the tank access plate. Drilled the access hole in the end rib. Drilled and prepped the cover plate, rib, and reinforcement ring. Riveted the nutplates and reinforcement ring to the rib. Fit and clekod on the fuel pickup tube anti-rotation bracket. Will have to wait to rivet it until I break out the pro-seal, becuase the two rivets that hold the bracket need to be sealed.
Cutting the rib with a cheap fly cutter. I threw this one away after one use and bought a nice one.
Parts prepped
Everything installed. The hole in the access plate is for mounting the float type fuel sender.
