Brief Description: Left Wing #8 - skins & Leading Edge
Moved all the top and bottom skin clekos one hole over so I could drill those holes to final size. Per the instructions I removed and stored the bottom skins for later and left the top skins clekoed on the skeleton. Put the leading edge (sits on the outboard portion of the wing) together in the cradle and then installed in onto the spar. This sure is alot of fun, even though I know there is still alot of work to do before actually putting this wing together.
Clekoing the leading edge together in the cradle
Cool. It's now easy to visualize the size of fuel tank portion of the wing.
