Todd's Web site
Date: 9-30-2006
Number of Hours: 7.50
Brief Description: Right Main Spar #3
Spot primed all the countersinks for the fuel tank attach holes. Borrowed a #28 drill bit from Furge, and drilled the holes for the #6 screws and nutplates. Finished drilling, deburring, and dimpling of all 6 access plates for both wings. Installed all the #6 nutplates. Realized I had messed up the the wing tie down when I drilled the holes. The plans call for you to measure and mark one of the top holes, cleko it to the spar, line it up perindicular to the spar, clamp it and drill the rest of the holes. Well, it looks as if somewhere between the lining it up and clamping it, I moved it and ended up drilling it while it was crooked. I'm only talking about 1/16" off here, but it was enough to bother me. (Dad thinks I'm crazy). So, I'll order another Monday...
