Todd's Web site
RV-8
Center Section #1
Started work on the center secion.
-Drilled the 5/8" rudder cable holes for the R-8 (RV-8A has a different location) using a unibit.
-Made 2 seat lug spacers per the plans out of tubing
-Deburred the F-804M seat Belt Attach lugs
-Fabricated the F-849 FWD control mount out of aluminum angle
-Fluted the center section bulkhead pieces that attach the spar.
-Clekoed the fwd bulkheads to the fwd center section spar and drilled the rivet holes to size
Enlarging the holes for rudder cable passthroughs
Had to fab this from a piece of raw angle.
Teaching Kaitlyn the fine art of fluting...
RV-8 Home
1131
Ailerons
Building Tips
Elevators
Flaps
531
Shop Setup
Stabs
Tribute to Jake
364
Wiring
