Todd's Web site
RV-8
Center Section #2
-Drilled and countersunk nutplate rivet holes per the plans
-Deburred the edges and holes of the bulkheads and spars where I drilled.
-Primed the 2 forward bulkhead pieces
-Installed, torqued, and torque striped 12 AN bolts to the fwd center section spar. These holes would have been used by an -8A builder.
-Riveted several nutplates per the plans
-Riveted the 2 bulkheads to the fwd center section spar.
-Clekoed the 2 aft bulkheads, seat ramp supports, and aft floor supports to the aft center section spar.
Fwd center section spar complete
Temp clekoed the fwd center section spar the floor. Starting to look like something!!!
Clekoed the aft center section spar parts together
RV-8 Home
1131
Ailerons
Building Tips
Elevators
Flaps
531
Shop Setup
Stabs
Tribute to Jake
364
Wiring
