Todd's Web site
RV-8
Rt Wing #15 - Install Leading Edge Assy
Primed (self-etching spray can type) the inside of the outboard top skn on the rivet lines.
Deburred, dimpled, and primed the wing walk doubler plate.
John Furge came over and helped me rivet the leading edge assy to the spar. He shot while bucked the rivets for the leading edge ribs to spar rivets.
While I temporarily installed the fuel tank to the spar, John riveted the leading edge assy skin to the spar with the squeezer.
Cleko'd on the the inboard top skin and wing walk doubler.
Bottom of Rt Wing, Leading edge and tank installed
Bottom looking at tank/leading edge seam
Inboard top skin cleko'd on
RV-8 Home
1131
Ailerons
Building Tips
Elevators
Flaps
531
Shop Setup
Stabs
Tribute to Jake
364
Wiring
