Prepared the stiffeners for the rudder. You have to do some ciphering on the plans to figure out how to cut them and trim them so they fit into the trailing edge of the rudder, but once you figure it out, it becomes pretty easy. This is the first time I really wished I had a bandsaw setup. A bandsaw will now officially go onto the list of desired tools. After marking with a sharpie, I did the initial trimming with snips, then put them to the scotchbrite wheel on the bench grinder. It all worked well!
