Brief Description: Prepared Lt Elevator parts for priming; Bent trim
Made the forming blocks to bend the tabs on the outboard of the trim cutout. Worked well.
Went ahead and edge deburred all of the trim tab parts and prepped everything for priming.
For priming the left elevator, I deviated from Van's instructions. For some reason, it says to prime the left elevator parts before the final dimpling and required countersinking is done. This is different than every other assembly in the empennage. I guess if there's a good reason for it, I'll find out later. In the meantime, I'm ready to do my last batch of priming of empennage parts.
Bending completed...should have taken a before shot...
