Made the doublers for the split floor. I wanted to lay it all out and match drill the doublers prior to shearing the floor to ensure it all fits right after I cut it. Layed out 2 lines of rivets on the rear section and used the stiffener holes on the front section to locate rivets and nutplate and installed the associated stiffener on the bottom of the doubler. I put a nut plate in every other hole. On the extreme outboard of the skins, I fabricated small doublers for one nutplate. Worked out great! Will try to get pics posted later...
