Mounted the Garmin AP Roll servo in the right wing. Bonded and riveted the mounting bracket in place. Mounted the servo on the bracket and placed the servo limit bracket. Needed to modify slightly to fit for the Titan configuration.
Mounted and drilled out the bracket and right wing lower skin for the Garmin heated Pitot tube. Clecoed in place. Primed the pitot bracket.
Mounted the Pitch Garmin Servo in the fuselage , Primed the bracket and placed the servo on with it's limit bracket in place. Clecoed the bracket in place above the tail wheel just aft of the elevator bellcrank.
