Tod's T-51 Project
Date:  4-22-2017
Number of Hours:  6.00
Brief Description:  Hydraulic Leak Fix
Hydraulic fluid was still leaking, so went through and removed every fitting and added pipe tape and sealant to all the pipe threads on all the fitting in each of the manifolds. The leaking appeared to be coming from the pipe threads of the fittings.
