Tod's T-51 Project
Date:  1-18-2015
Number of Hours:  4.00
Brief Description:  Hydraulic Dump Valves
Drilled and mounted the hydraulic dump handles in the center console. These handles pass through to the center section and will be connected to a steel wire to be able to dump the hydraulic pressure in the main gear and gear doors in case of a pump failure. This will open the doors and drop the gear and lock them into position.
