Brief Description: Dissassemble prior to Hard Pointing
All Controls are mounted to Control Tunnel from Team Tango. These must be removed so that all holes in the Control Tunnel can be Hard Pointed. Remove Foam Core around the inside of the hole and replace with Resin with structural filler and re-drill the holes. Took lots of photos at this point to know how to put it all back together.
