Tims Zodiac 601 QBK
Zodiac 601
ram air, prop, brakes
Mounted and torqued prop - set pitch at 2.5
Built oil cooler air intake and test fit lower cowl
Installed ram air ducts
replaced spark plugs
Added oil and turned over engine to build oil pressure and test fuel pump
Drilled and tapped landing gear for brake line brackets
Bled brakes
Wrapped exhaust pipe with high temp cloth
Zodiac 601 Home
354
Inspections
XL-B Update
