Tims Zodiac 601 QBK
Zodiac 601
fuel system, fwf components
Removed engine
drilled and final mounted air box
connected carb heat cable
installed gascolator, fuel pump, fuel flow sender, fuel pressure sender
wired fuel pressure sender, fuel flow sender
mounted cabin heat box
tested sensors on dynon panel
made fuel line from gascolator to fuel selector valve
Zodiac 601 Home
354
Inspections
XL-B Update
