A Picture of the table constructed before my first kit (that you see on the wall) arrived. The table is 4 by 12 build with plywood/Ibeam construction to keep it flat. 2 layers of 7/16 OSB glued and screwed together. I routered out an area for a 1/2 by 4 by 16 inch flat steel plate for back riveting. You can see the plate in the foreground of the table.
I plumed 4 air valves with gauges to help with running pneumatic tools. One supply line from compressor feeds the plumbed table. I also plumbed pneumatic lines across the cieling but find that I dont use them.
