Continue wet sanding left wing. 2 spots need paint repair. One is a pin hole (dark bottom) and the other was a pin hole that got sanded thinking it was dust in the paint. I sanded through the clear and base. I know this because the blue stripe color now shows. I'm going to try and repair this with a small airbrush. I'm thinking that this will limit overspray and blend into the surrounding clear very well.
