2 layers of bid FG tape above and below the foam where the front support brackets will be mounted and where the alignment slots will be located in the rear.
Also added some stripps that surround the sleeve for strength. I may run a strip along each edge after these laminations dry. It all depends on how solid the sleves seen to be.
