Cut and drilled aluminium angle as a bracket that will attach to the rear baggage floor support.
Changed my mind on the brackets. The aluminium angle would make the floor of the sleeve stand proud of the baggage floor. A flat piece of metal will make the floor flat if the metal is attached above the sleeve floor.
FG Layup on right sleeve.
Fab new brackets and bend left bracket to provide a flat fit to the floor of the sleeve while screwing to the top of the baggage floor support which is at an angle.
