Since the access begind the seat is so great with the rotisserie, I'm going to install the quarter windows in prep for final priming and painting of the fuselage. Peel back protective paper, tape, and test fit. Manual says to cut window to fit, but I decided to sand it with the hand held belt sander. Doing so allowed me to sneak up on the final shape for a perfect fit. This is the way to go! I taped the inside of the window to make it easy to clean up the flox squeeze out once the windows are bonded in. The outside tape is to set the line for scuffing prior to body work and priming.
