Received new NACA vents from Nick. Cut out entier recessed section in fuse. New NACA ducts bond inside and cover holes. This should make body work much easier.
I've learned that these are called NACA ducts because NACA tested air inlets and found this style to produce the most air flow with minimal drag.
