Test fitting the panel support is fast and easy with help.I'm quickly learning that I go much faster with someone who can confirm decisions and lend a hand. So now the plan is to do things that I am sure of alone and put off those things that I need to talk through or need an extra set of hands with.
Thanks, Dave. This build will be much easier now that you are regularly clocking in at the factory.
Clecos aren't always long enough. Will use combination of clecos and bolts next test.
