Brief Description: Fuel line, level plan, flap motor
Installed fuel pump and fuel line between selector and pump, continued wiring clean up, replace PVC spacer on flap actuator with washers (apparently, it's not ok to use PVC), and shorten left gear leg by 1/2 because the plane was not sitting level.
