There is a flap bracket that attaches to the wing root. Problem is that you can't use the flap to position the bracket because the wing covers the root. So, while the wings were attached, I hot glued a block of wood to the bottom of the fuselage and drilled a hole into the wood through the half of the bracket that is attached to the flap. I'll use this hole to align the root half of the flap bracket.
