Holing flaps up against the flap hinges to see on which side the bushing should be installed. My choices were obvious and once the brass bushings were pushed into the hinges, the flaps were temp. installed with bolts. Minor sanding was necessary on the trailing edge (TE) of the wings for the flaps to meet the root perfectly.
