Tims Lightning XS
Date:  12-15-2017
Number of Hours:  1.75
Brief Description:  BW - Rt wing
Final body work on under side of right wing. The low spot between the light pocket and tip is now flat, the tip/wing joint is invisible, and the sump canoe is now smooth with a thin layer of filler. I think the bottom is now ready for paint after I drill out the sump hole to final size.
Filled and smoothed
Filled and smoothed
low spot is now flat
