Cut hole in aft boot Test fit several times Fabricate brackets similar to left side with a couple of improvements. Broke inner bracket bending it, so off to aviation department at Lowes to buy more aluminum. Made outer bracket longer to maximize horizontal stability. Set nutplates Test fit
As with all other tasks, the second time went much faster. First bracket took about 12 hours (including think time) while this side took just over 4 hours including boot trimming and nut plate installation.
