Tims Lightning XS
Date: 9-14-2017
Number of Hours: 4.00
Manual Reference: 6
Brief Description: Trim Tab cont.
I have decided to mount the servo directly to the access panel cover plate. This will eliminate the need for screws on top of the elevator and should look a bit cleaner. Who knows, it might even make us fly a little bit faster too (ok, probably not enough to actually measure).
Making the plywood template was easy. Unfortunately, I forgot to install the trim tab control horn when I fabricated the trim tab (remember the florist foam,...). I was pretty sure that I fabricated the control horn, but cannot find it now. It is very similar to the canopy support bracket shape, so I'm not really sure if I made it or not. Bottom line is that I spent about an hour looking for it. Now, I believe I never made it in the first place. Not a big deal, but I wasted a lot of time looking for it and then installing it once I did make it (maybe for the second time). Just to be sure the control horn is secure, I drilled a hole in the part that will be bonded inside the trim tab. This hole will be a channel for the flow to form a little flox bolt and make sure the horn stays put. Bottom line is that I fabed a new control horn, cut out a slot in the trim tab to receive the control horn, epoxied and floxed the control horn into the trim tab and set it aside to cure overnight.
Finished product. Too angry with myself to take pics during fabrication
