Reinstall cylinder #4 CGT and EGT probes that I took off to access the engine mount bolt.
Replaced firewall/engine mount bolts, torqued to 450 inch pounds, and installed cotter pins. Top right bolt needs to be replaced because it's too short. I had to put too much torque on the bolt to get the cotter pin through the hole. I'll do that tomorrow.
