Tims Lightning XS
Lightning XS
Firewall, baffles and brakes
Added starter annunciator wire to starter contactor and wired to VPX.
Fabricated negative battery cable and connected it to the aft side of the firewall negative bus.
Finisjed wiring the master and starter contactors and shunt. Installed diode and resistor.
Bled brakes again due to air in lines.
Continued engine baffle fabrication.
Completed winring clean up.
Lightning XS Home
1921
465
Body Work
120
274
Cockpit
53
103
Elevator
219
Gear, Wheels, Brakes
57
Kit
Panel
229
