Prepare to lift engine. Must angle plane in factory because tail would strike garage door header if straight in. After measuring, it looks like it should work.
Step one is to decide where to strap the engine to the lift. After crawling around 15 minutes, I moved the bag of desiccant that was sitting on top of the engine and found a lifting ring. Looks like they thought of this already.
