Flock in fuse box mounting block. Fuse box for baggage lights, USB charger, and for electrical expansion in the future. Also flocked in a couple small blocks that I can use to mount Adel clamps. Relocate battery box. Yes, mistakes happen. I mounted the battery box on the floor where it sould interfere with the rudder cables. Missed it by less than an inch. Those cables are important and rubbing on the battery box would cause them to fray in time. A better place for it is mounted to the back of the seat back. Had I done this in the first place, I would have 4 fewer holes in the belly. Aargh!!!
Rout, tie, and hang wires. The ground wires still need some help. They could have been a bit longer to allow for a service loop. Fortunately, the ground bus can be accessed by removing the copilot EFIS.
