PrepAll and tack ailerons, trim tab, elevator, and canopy Bulldog canopy plexi that was exposed by taping back 1/8" from primer Spray sealer - got a few runs, so I had to let it cure an hour and a half before sanding the runs Tack after sanding and apply 2 (3 in a few areas) coats of base Spray 3 clear coats Remove tape from canopy about 2- minutes after the last clear coat to reveal a sharp line
Looks like I was too wrapped up in the painting process to have taken photos.
Paint colors are WA8624, Olympic (Artic) White and WA705U, Admiral Opulent Blue Metallic (aka Bosworth Blue).
