Tims Lightning XS
Date:  2-9-2019
Number of Hours:  3.75
Brief Description:  Prepare fuse for primer. Build rotisserie
It's going to be much easier to paint the fuselage if I can rotate it. Specifically, the bottom would be almost impossible due to the angle of the paint can on top of the gun. Instead of buying a hose feed attachment, Dave and I designed and built a rotisserie so that the plane can be rotated. On the firewall, the plywood has a hole to accept a 1" pipe. In the VS, a pipe is slipped into the elevator push/pull tube hole. With the legs off, the plane is pretty light and the fiberglass is plenty thick in the VS to support the wieght.
