The GTN 650 and GMA 245 make up the avionics stack. Each unit has a slide in mounting cage. These cages are mounted to support rails and vertical brackets. I did not allow enough space between the two cages and the units would not slide in. So, I had to remove the supports and elongate the holes used for the hanger supports. Once reconnected, the two units slipped in perfectly.
