Mounted ADSB Antenna to the antenna farm on test bed.
Fabricate D-37 connector for co-pilot HDX harness.
After pinning the connector, I realized the ADSB harness needed to be connectoed to the HDXs, so I added shielded wire to both HDX connectors. Image 1 shows the co-pilot side after adding the ADSB line. This is why the ADSB is not inside the shrink wrap. It is, however inside of the padded silicone tape on both HDX harnesses. The shrink wrap just makes it prettier.
