The Pitch Servo Mounting Plate interferes with the range of motion limiting bracket screw. So, I made a template to locate the hole and then drilled it. I'm going to wait to install the servo until I wire the D-Sun connector to the servo's wires. Too tight to work in the back for that type of delicate work.
