We did not account for the flute tube bolt head when fabricating the recess. The bolt head interferes with the recess. Best solution is to off-center the flute tube support bolt hole to allow the support to be mounted 1/4" out. This will move the bolt head far enough out to allow the recess to slip in.
Right bolt head
Left bolt head
Note original position - index marks on firwall flange
