Tims Lightning XS
Date:  12-12-2017
Brief Description:  BW - Right wing
I had a low spot on the bottom of the right wing between the taxi light pocket and the tip. It was too low to be filled with filler alone, so I built it up with 3 layers of fiberglass and glass bubbles. It is now within 1/16" from being flat. I'll level this out with filler once the epoxy has cured.
I like the glass bubbles because they are almost self leveling.
3 layers of FG tape plus balloons
Flat enough for filler now.
