Tims Lightning XS
Lightning XS
Horizontal Stabilizer - 3
Took lots of block sanding to get the back edge of the HS straight. This is important b/c the elevator will ride in this channel.
I used a wooden dowel the length of the width of the VS to space the leading edge while sanding. Then I bolted the spars together.
Still a bit to go. This needs to be straight.
Lightning XS Home
1921
465
Body Work
120
274
Cockpit
53
103
Elevator
219
Gear, Wheels, Brakes
57
Kit
Panel
229
