Tims Lightning XS
Lightning XS
Horizontal Stabilizer - 2
Drilled AOI holes into the hard points of the HS.
Installed seat belt cables
A bit of sanding on the leading edges of the wings and HS and used a chisel to cut off epoxy globs on tail and fuse.
Measured HS/VS again. Still within 1/16".
picture taken after AOI hole drilled, but before bolted to HS.
Lightning XS Home
1921
465
Body Work
120
274
Cockpit
53
103
Elevator
219
Gear, Wheels, Brakes
57
Kit
Panel
229
