Press bearing into outboard aileron hinge. Use wide area washer anywhere a bearing failure would allow the bearing to pull through a bracket.
It took a couple of washers to position the outboard aileron hinge in a position where the trailing edge of the aileron would be straight with the flap. Because there are washers, I'll need to flox the gap between the back side of the hinge and the wing.
