Cleco in place temporarily on last time to test fit. Looks ok. Flox upper flange on wing tip, squeeze and slide into place. Grease clecos so they won't stick to the flox. Clean off flox that squeezed out. Flox gap in lower leading edge. This is was a pretty big gap as you can see if the second picture. Let cure overnight
