The Redheads RV-7A Build SIte
Date:  9-10-2011
Manual Reference:  Wing Flaps
Brief Description:  Fabricating the Wing Flaps
Image 1 shows how I match drilled the aft end of the Flap Ribs to the Flap Bottom Skin. I quickly discovered that if you didn't support the tab at the aft end of Flap Rib when you tried to match drill to the lower Flap Skin you bent the tab. Image 2 shows how I clamped the Flap Drive Bracket Assembly to the Inboard Flap Rib and the Flap Spar. It took a little jockeying around to get it to fit up nice and tigh and flusht. Image 3 shows me match drilling the Flap Drive Bracket Assembly to the Inboard Flap Rib and the Flap Spar.
Match Drilling the Aft End of the Flap Ribs to the Bottom Skin
Flap Drive Bracket Assembly Clamped to Inboard Flap Rib and Flap Spar
Match Drilling the Flap Drive Bracket Assembly to the Inboard Flap Rib and Spar
