Brief Description: Preparing for the Stall Warning Kit
I was surprized how quickly the Dremel cut-off wheels wore out making the access hole cuts. I used one cut-off wheel for two edges. Image 2 shows the preliminary access hole. Image 3 shows the tool provided by VANs that will locate the holes for the bracket that supports the stall warning sensor and the holes that will locate the slot in the leading edge the Stall Warning Kit sensor pokes through.
Dremel Cut-off Wheels Don't Last Very Long
The Preliminary, Undersize Access Hole
Installing the Tool that will Locate the Remaining Holes for the Stall Warning Kit
