Started working on the Wing Ribs. There are several ribs to be aware of. There are the outboard leading edge nose ribs, the fuel tank ribs, the outboard middle ribs and the inboard middle ribs. After opening up the packages of ribs and marking part numbers on each of the ribs in case the lable falls off. Then began the arduous task of deburring all of the ribs.
